I'm still having flooding issues with #1 carb, it seems. However, all the plugs read white now. The bike starts with choke, but seems to not catch easily. I have to start a couple of times, then shut off choke once running, then throttle it and leave the throttle lock at 2000 rpm for a couple of minutes. It idles fine, no smoke, though sometimes the idle drops erratically. There is a constant drop of gas on the float bowl drain screw. I couldn't get the float in #1 to pivot totally free. I changed the pivot pin, float, etc. It seems there might be a casting problem with the pinion, ie alignment, so that it causes a 'wow' in the pin or something. It slides in easily, then at the last 1/3rd of the pin length i have to tap it into place. I don't want to break the aluminum pinions by trial/error tapping on the float pin to 'straighten' it? Also, worried about over-sizing the float pin mount holes in the pinions by burnishing them or reaming with a dremel. Suggestions? I'm only getting 28-35 mpg now. Maybe i set the float too high in an effort to seat the float valve? Before i was having fuel leaks, but at least 40mpg.
