Ok, so here's the lowdown; I bought this 82 GL 1100 for 350.00 complete bike except for battery cover, go figure, the guy said it sat for over three years but ran pretty good before that. I checked the compression (cold) good on all cylinders, turned it over and listened for anything obvious.....sounded good.
I knew I would have to pull the carbs off and clean them up at the least to get it to run, so I did, and they were pretty bad. I pulled the tank, cleaned it out, changed fuel filter and put it all back together. I bought a new battery and changed out the relay, pulled off the starter, disassymbled cleaned and inspected and tested all good, put it all back together. Lubed all the cabels I fired it up and dialed in the carbs as best as possible by ear, and it has run, but not right... So I hooked the vacum gauge up and and the left bank has poor vacum, the guage was ossilating back forth very fast and in the red zone on #1 around 5Hg.inch and#2 a little higher. I checked the vacum test ports to make sure they weren't blocked. So at this point I was depressed, I checked the other side and both cylinders were reading 20+hg.inch in the green with a slight ossilation on both.
So I'm thinking intake valves aren't seating at best, or worse maybe they are bent from a timing jump.... I sprayed some WD40 around the intake ports while it was running to see if the idle whould change to indicate maybe a leak at the intake manifold, but nothing.
Is there anything I may be missing here? before I pull off the valve cover and inspect the cam/valve terrain..... I really don't want to pull the head. Any ideas?
Thanks,
Patrick
Thanks,
Patrick
