I have a 1985 ltd, has a poorboy with a 2 and a half inch crank pulley, charges 11.7 volts at idle, I have heard of people using a 5" pulley would that over rev the alternator? I have a denso alternator
Poor Boy voltage output
Are you relying on the factory volt meter? These meters are known for their inaccuracy.
I too have an 85 LTD with the PB conversion. Mine show almost exactly a 1volt difference between the factory gauge and my digital meter attached directly to the battery.
Check your voltage at the battery for a true reading. Good Luck!
poorboy sells his kit now with 3.5" pulleys,i have a 4" serp on mine and it charges at 14.1-2 vdc
also the alt is turned on at 1000 rpms which allows my charge to be 13.6 or so at stoplights with all lights and two driving lights on
