Power loss 1988 GL1500 (engine)
721 Views 6 Replies 7 Participants Last post by  Notewriter
Hi folks, the 1500 trike has started playing up.
On a ride started loosing power as if fuel starved then cut out, didnt want to restart but eventualy did, carried on but seemed down on power cut out a couple of times.
This is an early UK 1500 (88/89).
Leaning towards possible fuel pump or vacuum tap at moment, any ideas folks all suggestions welcome.
Cheers
Bryan
Might be as simple as a plugged gas cap.
If it's not missfiring then yep, it's probably starving for fuel.
  • Like
Reactions: 1
What was the outside temperature and how much fuel was in the tank at the time?
Just to add, the fuel pump operation is a very simple thing to check. Just need a jumper wire, some spare fuel line and a glass jar.
Torn rubber diaghpram on vacuum fuel shut off valve?? (If they even had that valve on the early 1500 Gold Wings.) Maybe a plugged fuel filter? I got some bad gas one time that I had a heck of a time with.
gumbyredd
my '98 1500 had a weak fuel pump, replaced it with a NAPA unit
Cheers
Bryan
A few simple things to check, 1, fuel cap venting properly, 2, in-line fuel filter, 3, fuel vacuum shut off valve under fuel tank access lid, 4, fuel pump filter screen/sock, (you’ll have to pull the fuel pump out of the tank to clean the screen/sock.)
