alanz wrote:
Can you think back to when the problem started? Was anything added or changed around that time? No chance you added a free flowing air filter or something similar?
Is this only a 3000 RPM acceleration problem? Or do you get in in all gears at different RPM roll on's?
Here's something to check into,, the 1200 Wing uses an input to the ign box to allow 4th & 5th gears to use a vacuum signal to control spark instead of a fixed spark curve.. I can't tell you if the 1500 uses the same type system or not.. Maybe someone with a 1500 manual or that has researched the 1500 spark control can shed some light here. IF, your bike has such a system & theign system doesn't see a 4th or 5th gear signal you wouldn't get much spark retard on acceleration in the top gears. (kind of just tossing this out here as I have no idea if the 1500 has such a system or not)..
Twisty
alanz wrote:
Al, formulating a list is great way to work your way through your problem.. I'm not sure why Vic thinks you are "running around like a chicken with his head cut off" butthat is his opinion not mine. It sounds like you have a good planof action & you are asking plenty of questions so should have a good idea where to look & what to check.I've had a 'look' at my vaccuum hoses and they seem to be ok, however, that is only the ones that I can see. As everyone, here, knows they go all over the place and you can't check them all until you pull the bike apart. I will add it to my list. I realise this is going to take some time.
You are right about the supply of parts. The Gold Wing is not the most common bike over here and the parts supply is not good and very expensive. I tend to buy from the US over the Internet but that can take a bit of time.
The cost of fuel here is NZ$1.52 = CAN$1.21 = US$1.03.
So that actually compares pretty well with your prices. We thought we were hard done by because the prices have skyrocketed. Guess it is happening everywhere.
Twisty
