1 - 12 of 12 Posts
I read the manual, 0-25 settings and how it works.Yes, how much you weight and what kind of ride you want, BUT, BUT...
HOW do you know WHEN it's adjusted correctly??? WHAT to look for, that tells you, "that's it"
THANKS
GL1800-2006
More info, need more info.
Anytime I adjust any suspension, I am looking if I'm one-up, or two-up, and whether I bounce, or bottom out going over rough roads, train tracks, etc. It depends on your weight, your passenger's weight, and your own personal comfort level. The owner's manual should give you some kind of baseline setting, or recommendations, or maybe not.
Disfunctional Nimatode
"It depends on your weight, your passenger's weight, and your own personal comfort level."
Mikef sums it pretty well right there..........I set my shocks so they just get by without bottoming out with 2 up. And, I run with at that setting while by myself also. This gives us that softest ride we can get while 2 up..... and gives me a little more firmer suspension while by myself if I choose ride a little more agressively. You don't want to be bottoming the shocks too often...... if at all, if all possible. Other than that it's up to you on how firm you want them.
I might add that I have progressive non-air shocks and they are a pain to switch back and forth(cuz of the bags).... so I settle for the above senario. I do like them alot.
THANKS
GL1800-2006
I just played with the setting until I found what felt good to me. The setting will vary widely for different riders and different bikes. One up, two up, rider weight , riding style, spring condition and pre-load lag are all factors.
With the stock spring I would keep mine at 25 all the time, but I prefer a firm ride and weight 300 pounds. With the heavier Progressive spring I usually leave it at about 16 when I'm riding alone. If I'm riding 2 up I set it about 20. When I'm riding hard on twisty roads I move it up to 25 so I don't scrape my as feet often.
Th
I suspect at this point you still have no idea where to set your suspension huh???:D
I weight 200 and my wife is around 160. With a full load and pulling a trailer we set it at 18 and have never bottomed out.
When riding 2 up on a day ride it's usually set at 10 and still have never bottomed out.
Riding solo I set it at 8 but not sure if I should even bother because I suspect the difference from 8 to 10 in minimal.
I hope this helps a little bit at least. :waving:
hi Wrongway, good to see you posting, I run my suspension at about 8 solo and 17 with 2 up. again never really noticed any bottoming. 25 just makes it easier to put the bike up on the center stand. john
Hi John:
Do you still hit deer at 25???????????? SORRY, couldn't resist!!!!:cooldevil::D
Hopefully we'll get our your way for a ride this spring. :waving:
DEER AHEAD< RAMMING SPEED
Discussion Starter #10
I like to take the time to thank everyone for all your advice. I beging to see the lite, now I understand alot better what I'm after, thank you ,one and all!!! Have alot to learn.
wrongway wrote:
Hi John:
Man..... thats cold I tell ya. Got any jerky ready?:clapper:
Go forth myfriend, and rip up asphalt like it was your own...........:action:
1 - 12 of 12 Posts
