1 - 12 of 12 Posts
· Just Winging It
My shut off valve is letting gas flow in the off position.
I have a leaky float valve.
What do you guys think about installing one of these.
Where would you get power from? 1986 1200
http://www.dan-marc.com/79-afc11112.html
· Just Winging It
Discussion Starter · #2 ·
Maybe I should tap in to the power to the fuel pump?
I've been looking for something like that for mine. Thanks for the link. I would wire it to the tail light power feed.
· Administrator
1987 GL1200 Interstate
I have an OEM gasket for the pre-'87 petcocks, Jeff. If you are up to the task of installing it, (and no, that's not a challenge) you may have it.
It takes considerable drilling, grinding and tapping to disassemble and fix those little devils.
· Just Winging It
I rebuilt the petcock on a Honda CM400E 1980. I don't remember any drilling or grinding. There must be rivets holding it together. I will think about your offer Dennis.
· Banned
1200I = Interstate? Carb model, right? Not injected.
Can use a much smaller solenoid than that one.
Less than $10 on eBay new.
· Just Winging It
Discussion Starter · #8 ·
Which one could you post a link. Yes a carb model.
· Banned
Plastic or metal body won't matter. A streetbike is light duty in application.
Take your pick.
I've ordered from China with no problems in the past. Probably a few dozen times thereabouts. I've waited up to a few weeks at times for delivery though. Depends on fast you want it as to what you'll pay.
Sometimes a auction is the way to go depending on what you want.
· It aint rocket science
If it was my ride I would fix the defect.
A leaking float valve is washing the oil out of the cylinder and tanking fuel mileage.:sadguy:
This is a case where money spent will come back in fuel savings.:?
· Just Winging It
Discussion Starter · #11 ·
I agree, God willing, I'll rebuild the carbs this winter but not during riding season if I can avoid it because I'll order my parts after I see what I need I could have a sinking float or badly adjusted float height or dirty valve.
In the Honda owners manual it says to shut the fuel off when your not riding I always forget.
Although, when I have the time I'll take the carbs off my parts bike and rebuild them so I can just swap them and tune them in. I guess I hadn't even thought about the other carbs.
· Just Winging It
Discussion Starter · #12 ·
Take your pick.
I picked the one I did because I wasn't sure how well the plastic ones would hold up in the heat from the engine. If it quit working so would the bike.
1 - 12 of 12 Posts
