You going to do it yourself or take it to a shop?
Brakes are pretty simple to replace. Do it yourself and $38 a set for OEM pads so $114 for pads and couple dollars for shipping.
http://cyclemax.com/inc/sdetail/gl1500_oem_honda_brake_pads/158744/110377
If you take it to a shop it could cost anything! Honda charges allot more for the same pads, and then labor of course. Expensive.
Any good small shop should be able to do them also but price can vary a ton.
It's a simple job to replace all the pads, and we can walk you through it.
It will take you about 4hrs the first time.
Oh - THAT guy...
It (a shop price) will vary greatly according to quality also. The slider pins for the two caliper halves need to be cleaned and greased, etc.
Doing it yourself saves a shop rate hovering at or over $80 an hour and is fairly straight forward.
More expensive is not always better though.
In some areas you might find a really good small shop for about $25 an hour that does great work.
I have been to several small shops for many things that do great work cheap compared to others around which cost far more and do crappy work.
Best thing sometimes is find others in your area with similar stuff and ask where they get their work done when needed and if it was good work. Or do it yourself if you can which is almost always best.
Oh - THAT guy...
Lots of resource available here if you need or desire it.
I think I pad $40.00 for my pads from the local Honda Dealer here in Salt Lake. If you have replaced brake pads on a car you won't have a problem
