that is the kick starter. Remove the rubber plug from it and then take the right side cover off the false tank. The kicker should be there. put the kicker in the hole and move it down out of the way. You probably have to tie it off. I use a 3/8 breaker bar with a 12mm socket. Lift UP ONLY on the bolt. JB
