1 - 1 of 1 Posts
Guys and Girls I bought a gl1200 ltd instant love connection you know between man and machine Anyway the place where I bought the bike, told me a tree feel across the bike and all I had to do was replace the trees no problem right, wrong! hadto replace the frame cool huge. wrong again it has a wiring harness big enough to chock a horse.Anyway after getting everything transferred from one frame to the other. I found a problem Little problem at first but then it got worse and that was shifting the gears it was the damper plate it was separation and by not finding the problem in time, theplate seperated the springs came loose went into the oil pump shaft gear and broke the oil pump shaft. So word to the wise if you are having problems shifting gears and find no leaks and no air in lines and slave cylinder, better pull engine and pull cover off rear engine and check out clutch plates
1 - 1 of 1 Posts
