Well mybike has been running great up to now. Heres the problem
The little off idle stumble is getting worse. It was gone for a few days after changing thermostats. I took out the slides and added 21 thousands washers under the needles made no difference other then i lost 4 miles a gallon. When i had the slides out number #3 needle had a whitish deposit on it at the taper end. So i suppose i need to take them off. I have ran sea foam for 2 tanks now.Question is Do you think a good cleaning will do or should i get the full rebuild kit. Im thinking a good cleaning will work my self i cant see needing any needles,floats,jets as it seems to run fine other then when i crack the throttle open.
Pat
Pat
