Finally got my 416's. Which way is the best way fore or aft for the airlines on GL 1200 Asp.?
Only fit one way on an 1100, aft. Probably the same way on all bikes
I run mine aft in a similar fashion to the OEM lines. I extended the length of the new air line (allowing for any future repair) to have some hose already available in the set up. The extra line, coming from the Progressive adapter was run through the original guide on top of the rear fender to the aft of the truck mounting bolts on either side of the fender. Then returned forward along the side of the fender to the shock.
Have them installesd and air lines run. Putting the bags and trunk back on and should be on the road again
