Hi guys my 1500 has this system fitted but what pressure should i be running it at i dont have any paperwork for it so dont have any idea, on the comp. guage it shows about 50 when you press the check button
it sounds like a previous owner has swapped the standard shock for an air one never seen a 1500 with twin air shocks.
Yes the kit is available for them this bike came from cal imported in 2003 its a nice ride just dont know for sure if the pressure thats in is high or low feels ok on the road
My 89 had Progressive 416's. They are dual air shocks, one each side. It replaces the stock suspension. I used to run mine at 30 psi - 2 up and 45 psi - 2up with a trailer. I also had progressive springs in the forks and a superbrace. It was a hudge difference in handling and suspension, but the stock suspension was worn out.
Progressive 416
Note that Progressive states that 100psi will shorten the shock life. I use around 20psi on the rear shocks (Progressive 416) when solo and 55psi when two up. I carry 0psi in the forks which have progressive springs, both solo and two up.
