My 1500 is leaking I think shock oil after a hard bottoming out.are progressive shock rebuildable,should both be done together?
Yes they are rebuildable , progressive have spare parts . I would repair the one who is in need .
If you turn it upside down and compress it a little you will se a wire "snap ring" , - remove that one and you can take the rest apart .
