Progressive Suspension Fork Springs Goldwing GL1100
are these of any use or just more weight??
Neil
Neil
Not sure what you mean by " just more weight " They dont weigh substantially any more then the stock springs , which are actually 2 springs in each fork . Do they allow you to carry more weight on the bike ? I am not sure of that . They do provide a better ride . They also might raise the height of your bike a bit because your stock springs are likely 25 yrs old or more and tired ( sagging ) . Some folks find they can also run less air pressure in the forks with progressives .
Huh? All you do is unscrew the top cap and pull the old springs out. Not major surgery....The springs are inside the forks-- which means disassembling the front end. The progressive rate springs replace your present springs, recommend new fork seals at the same time. They really work. I also rebuilt my rear shocks with new seals & fluid -- that makes a difference too.
