I have moved two Goldwings on trailers. One trip was about 250 miles, the other was 740 miles. I put the bike on the trailer and leave it on the side stand. It won't be there long.
I find four locations where ratchet straps can be attached to the bike. I check the routing of the straps as I attach them so they aren't against any plastic parts. The two rear straps pull to the rear and the front straps pull the front wheel against a stop or wheel chock. They are looped through, not hooked. I run the straps around the frame rather than the forks. After looping the straps around a good solid point on the bike I attached them to the trailer.
Now I begin to ratchet the straps on the right side of the bike to pull it up from the side stand. As I do this I make sure the left side straps are short enough to keep the bike upright and the front wheel is pulled snugly in to the chock. Snug all the straps, make sure the bike is straight up, then tighten the straps. The bike is not on any stand.
The bike is supported on its suspension and held upright by the straps. The suspension is slightly compressed. If you leave the bike on the center stand is has no cushion from road hazards and bumps. The stands are to be used only when the bike is parked in the driveway.
The longer trip was from Nebraska to Minnesota, through rain, construction zones, rough roads and lots of traffic. The straps did not loosen and the bike was still on the trailer when we got home. The straps were anchored to the trailer with eye bolts through a 1/2" plywood floor with fender washers top and bottom. They held very well. I do check the straps at every pit stop just for reassurance.
It's a 700 pound motorcycle, not a D9 Cat!
