Hey Frank, if you look on page 239 of the Clymer manual, gives a pretty good removal process. I had a tire rub too, but it was rubbing on the brake caliper torque tube. You do need to remove the lower mount for the right air shock. It also says to put a couple of 2X4's under the rear tire so you can get the axle out. You'll understand once you start to drive out the axle.
