The 84 model Wings had the PG's mounted in the rear of the engine. Inside the alternator housing I believe...
You may be able to do some measuring,(using your old engine), then drill/tap some holes. You'll also have to use the pully or timing tab from the old engine so the PG's have somethingto sense for a timing reference.. :gunhead:
