1 - 12 of 12 Posts
An old indasher I had laying around, tied it into the speakers and put a new cheapo antenna on the trunk, put the cd in the l/bag. Wow it work 10 times better than the old Aspen system. I am now sure that the old system is to complex, to heavy and not very good.. No I will not sent it out to be fixed, It is not worth the money,
I found a new JVC unit that plays CD/dvd and has a GPS too all in one din..
I am going to change some things on the old Aspen...
Just found this one: http://www.salientshop.com/43inches-car-dvd-player-bluetoothnavigation-system-p-219.html
specs:
  • Primary Function: Vehicle multimedia player and Bluetooth system with4.3 inch display+ Navigation system
  • Discs/Formats Played:
    -Discs: DVD, CD, VCD
    -File types: MP4, AVI, DIVX, XVID, VOB, MPG, MPEG, MP3, AAC, JPEG
  • Operation: Touch screen or remote control
  • Display Information
    -Screen:4.3 Inch TFT LCD
    -Aspect Ratio: 16:9
    -Resolution: 480x234 RGB
    -Angle: 0 to 90 (motorized sliding display panel)
    -Brightness: 300 cd/m2
    -Video Systems: PAL, NTSC, AUTO
  • Bluetooth Functions
    -Pair with phone - then use touchscreen interface
    -Dial, Receive, Disconnect calls
    -Volume Control
    -Touchscreen keypad
  • Audio Information
    -Max Audio Output: 50W x 4
    -Signal-To-Noise Ratio (SNR): >85dB
    -User adjustable EQ, Bass, Treble, Fade and Balance
  • AM/FM Tuner
    -AM Frequency Range: 522~1620KHz (worldwide)
    -FM Tuning Range: 87.0~108.0MHz (worldwide)
  • TV Tuner Information
    -TV Type: Analog
    -Tuner Frequency Bands: VHF-L, VHF-H, UHF
    -Color Systems: PAL M, PAL N, SECAM DK, NTSC, PAL I, PAL DK, PAL BG
  • Front Panel Controls
    -Power ON/OFF
    -Reset
    -Mode select
    -Volume dial
    -Radio band select
    -Disk eject
    -Built-in MIC
    -Answer calls/AV settings
    -IR port
    -Forward
    -USB port
    -Faceplate detach
    -Back
    -Display angle adjust
  • Media Inputs
    -USB drive slot
    -SD/MMC card slot
    -DVD/CD disc slot
  • Cables/Wires
    -Radio Antenna IN port
    -TV Antenna IN port
    -RCA Audio OUT x2 (front L and R)
    -RCA Audio OUT x2 (rear L and R)
    -AUX Audio IN (R/L)
    -SUBWOOFER OUT
    -Video OUT
    -Rearview Camera IN (AV Video IN)
    -AUX video IN
  • Certifications: CE, FCC
  • Dimensions: 181mm x 165mm x 50mm (L x D x H); depth = 211mm including front panel
  • System Main Menu (color icons) Language: English
  • DVD Menu Languages: English, Chinese, Spanish, Italian, Russian, Polish
  • GPS Information:
    - GUI Interface: YES - 3D type
    - Touchscreen Interface: YES
    - Operating Environment: CE 5.0
    - Menu Languages: English, Simplified Chinese, German, French, Italian, Netherlands, Traditional Chinese (Actual voice and display language depends on GPS software package)
Product Notes
  • Touchscreen Control
  • Bluetooth Enabled (including A2DP)
  • Fully Motorized Screen
  • Adjustable Screen Angle
  • Remote Control
  • GPS is available with this unit
Package Contents
  • 4.3"inches TFT-LCD Car Stereo AV System with Bluetooth Touch screen+Navigation system
  • Detachable Faceplate
  • Remote control
  • User manual - English
  • ISO wire harness
  • Mounting hardware
  • Touch pen
  • GPS Antenna
  • 2GB SD Card with Evaluation Software
  • Dish washer
  • Kitchen Sink
nailgun wrote:
Can a GL1200 pull a Dish washer and a sink?
Only if you have a good chain....:tongue:
I AM afraid to say that that unit its too big to fit into the 1200s dash, you may want to keep it water/proof somehow, for the gps function it needs to be right in front of you.
William that unit is 6.5" deep, my stock system is 51/2" so I need 1" to make it .
I checked an 1" further out won't be a problem.
My goal is a complete re-do of the dash. Mine is cracked and ugly . I am going to look into moving the speedo and tach up and back about 1".
If it works out most all one din type audio systems should fit no problem.
Click on the link.. doesn't have a CB, tho . . . hee hee
The radio went out on my 85 Aspy when I had it and put a Jensen in dash unit out of my old truck. With a bit of finnesse and a bit of cursing I got it to fit and it worked like a champ. It did'nt have the functions like the handlebar control and so forth but for the money it was waoth it.It was in it when I sold it and I imagine its STILL in there.
Discussion Starter #11
I see it in that photo, looks very good and a clean setup.
good job vtxcandyred.
1 - 12 of 12 Posts
