1 - 3 of 3 Posts
hi there,
I have almost finished my Gold Wing "adventure".
Changed the stator and other things,and I have started the bike this morning.IT WORKS!! Over 14 V at idle.Great I made it.
I have to be honest.
It is not so easy as some of you say.And bear in mind I do have a forklift and a transpallet too.
THEY WERE OF GREAT HELP TO UP AND DOWN-FRAME INTO ENGINE AND VICEVERSA.!
Now I am asking all of you:
On the top of the radiator I found a female 3 wires connector and have no clue where it is sopposed to go... any help also the two pipes black tank that has to do with air filter...where is it positiobed?
Thanks guys
Lucio
Other side of the pond
Can't help you, but I'll bump it up for someone who might be able to. ;)
Sorry Lucio, I can't help with the connector either. The black tubes and plastic tank sounds like the breather returns and catch tank. there should be a hole in the air filter for one end of the hose/pipe. I believe the tank mounts down low on the left side of the frame near the starter.
I have to get my manual back, Wing is in the garage and it's pouring down rain...
It wasn't that bad now was it ?;) Great job. Now you have the satisfaction of knowing your Wing a bit better. :gunhead:
1 - 3 of 3 Posts
