I think I spoke too soon when I said the 1500 was easier to get to the timing belts than the 1200. I based that on not having to drain down the cooling system and taking the seat and top cover off. I was hearing a little tickety-tickey noise at times yesterday that sounded like it might have been coming front the front of the engine so today since it's raining I pulled off the timing belt cover. Wouldn't be too bad it it weren't for that air duct tube. After getting the cover off I found the belts a bit too loose. I pulled the two idlers out to take a look at them and now find myself in a quandary as to whether to replace them. I think I better since there is a minute bit of free play when you try to rock them on the shaft and I can hear a little sound, not much, but some when I spin them. Sometimes PMs can get obsessive.
I must say the 1200 was made better, cast front covers and cast cam sprockets compared to the plastic cover and stamped cam sprockets on the 1500. Just looking at the sprockets makes you think the 1200's would treat the belt better.
