I am still learning how to dial in all the settings on my (new to me) Wing.
I have been running at 40 to 42 PSI and that seems OK with the wife with me. I ride by myself a lot to work and was wondering if I lower the press. will it ride smoother and if so how low can I go and not damage anything
Thanks,
George
Oh - THAT guy...
They are designed for 0 to 57 psi. Pump it/adjust it while on the centerstand.
No damage in that range solo/double/etc. Lower pressure will make it softer and maybe a tad lower to the ground, and higher will be more stable in the corners. For the most part.
Rich
I run mine at 20 solo and like how it rides on our washboard roads here in So Cal. When I fill the bags and have a cooler on the back seat from the Costco run, I bump it up a few pounds. That is the nice thing about this system, you can adjust it to the road/load!
They are designed for 0 to 57 psi...
That's for the stock suspension... If you have Progressives, then you can go up to ~90psi
I crank mine up all the way, because it makes the handling so much better, especially with a load.
