Question for 84-87 carb guys
706 Views 11 Replies 3 Participants Last post by  escogold
Does each carb have this spring? Thanks.
I took apart carbs 2 weeks ago and today begun assembly. Couldn't find 2 springs.
One more question. How do you install pilot screw O-ring? Do you put o-ring on pilot screw or put o-ring in hole first and then pilot screw?
1 - 12 of 12 Posts
yes you should have four of them
although as i recall two of them are just regular springs without the hooks.
Thanks, I have 2 different springs and I suspected they go instead of hook springs but I have no idea which carbs they go on and how to install them.
Can somebody look at his bike, please?
If you don't look I will install banjo cords and attach them to rear fender...:)
I really need to buy LTD or SEi, I am not smart enough to deal with carbs...:(:)
Thanks for your picture, it shows hook spring. Where different spring go?
no. 1 and no.4. don't think it really matters as long as you got one hook spring on each side. somebody got at the carbs i'm looking at before me so not positive. if you don't get a definitive answer from somebody else i'll check my other 12 in the morning. nobody's touched those yet. i'll have to pull the covers and it's getting dark out.
Thanks a lot!!! The best people are here!
de nada. couple quick tips unless it's too late. disassemble the carbs one at a time so as not to mix up parts from one to another. keep one carb bank assembled so you can use it for reference for the other. don't interchange the jet needles. they are all specific to each unit. replace all the fuel/vacuum lines. mark the ends of every line with masking tape from whence they came (sorry i'm currently watching "life of brian").
My carbs just had two, one of each side.
you put the oring on the pilot screw and then carefully screw it in.
I finally begun final assembly and still didn't get info.
to William86: which carbs have springs and which don't? 1 & 3 carbs are on right side and 2 & 4 on left( I think).
To EscoGold: you can probably see some springs w/o removing chrome plates, could you look please?
To all: Maybe somebody doesn't have chrome covers, could you look please?
Well, weather is so nice today, everybody is riding probably...
Any Alaska guys here? :)
Thanks.
Sorry to leave you hangin' new'b. Just pulled the necessary hardware. The hook springs are on #1 and #4 so my above reply was correct. There are FOUR springs though. One on each carb. Thanks, been meanin' to polish the chrome carb covers anyway. Come to think of it now that the valve covers are exposed and if I pull the crash bars I can get at the timing cover...... It's sunny and about 72 right now. Where's my helmet?:waving:
1 - 12 of 12 Posts
