What numbers do you usually get when you use the auto-set suspension. Just curiousmy bike rides fine but the numbers seemed high. I get 15 to 18 lbs on the front and 90 to 110 lbs on the rear.
My air pump has decided to give up the ghost. It runs but provides little or not pressure. RUnning for 60 seconds only gives me maybe 10 to 15 punds static pressure at the shrader valve fitted on the fairing for hooking thehose up.
Got to figure that one out,
However, your question. before it decided it did not like compressing air. My front forks it would autoleve in the 2 to 4 psi and in the rear similar to you. 90 to 110 psi, especially with a passenger on the back. I have progressive springs in the front though and progressive actually recommended 0 pressure in the front, or at least that is the way I read it.
bob
· Postpubescent member
I used to run my SEI with around 50psi in the rear. 90-100psi seems a bit high, it might be that the oil is low in the shocks, that will make it feel soft handling.
Thanks guys, They bike rides great, one up or two up but the numbers seemed high. I wondered if it was just something to do with the LTD.
· Senior Guru
I went Progressive, and the pressure went down to 35 psi, riding dbbl.
