Hello every one ,
I have a an annoying question , when I was on vacation , the bike was running since 2hrs and more , I have stop at a stop light and the idle was going from 1000 to 500 up and down .....until i get back up to speed.
So I was wondering if this is a common issue or something I need to address?
thank you
Don't know about the 1800, but I had a VW rabbit that did that, turned out to be a vacuum leak, might wanna start there.
well that have happen just once in 8,000 miles
since last time the bike have never done that again ....
Maybe a tank of questionable gas? If it hasn't done it again, I would just ride it.
You should do nothing, andget it doneas soon as possible! ;)
Just another ORF!
Soso .... sometimes the idle adjustment screw forward and to the right of the gas cap needs to be turned up and then down a couple of times, before finally setting your idle to ~ 750 RPM.
If you want, bring the bike around to me at the campground this weekend at the National Rallyand I'll take a look at it and show you.
Dusty
Piled Higher and Deeper
Definitely try what Dusty says... I've no idea what happens when you screw it in and out a few times, but it seems to help... I'm guessing it is loosening up something with some "sticktion".. dunno..
