1 - 15 of 15 Posts
I just picked up a 1985 Interstate.
Reading thru the forums here, I looked into the yellow wires.
And there it was, the white clip/plug.
I was going to do the soldering tonight, and realized Ihad no shrink wrap, so it will have to wait until tomorrow.
I figured I would prep the area and get it all ready.
Here is the part I am suprised about:
Upon looking at the wires, I found that the original honda wiring was Yellow, thats what comes out of the eingine. However, 2 inches below abd above the white plug, the wire is yellow with a black line, and someone has soldered to shrunk wrap the yellow with black line to the original yellow. The PO did not do any work to this, however he is not the original owner.
SOoooo what could have happened?
Original white plug burn and they replaced it with something off another model?
Did they replace the stator and the put in a new plug?
What should I do? THink? OR just solder it and be on my merry way?
Your thoughts and opinions on this are much appreciated.
Also, since I have a interstate and it doesnt have the fancy volt reader, is there something I can add thats not real expensive but will allow me to watch the battery?
Rob
Who knows. I already removed a 4 pin trailer connector someone had wired in place of the connector. Clean back to solid clean wires, solder and shrink wrap and you're good to go.
Are you sure the battery is being charged? You may want to test the stator, before you solder the wires, just to be sure.
Do a search for stator testing.
Kuryakan makes a reasonable priced gauge, about $34.
Hi Robo74,
Just to double check we're talking about the same thing, you're looking at the connector that's close to the rectifier/regulator under the left side of the faux tank, correct? Assuming this is so and you have solder/shrink wrap connections on the 3 yellow wires on both sides of the connector then it sounds like someone replaced the connector at some point. I recommend you proceed with removing that connector and hard wiring. $.02 from a EE.
Dan
If you are talking about the connector to the right of your battery trace the wire loom up from rear of engine to the existing connection point . It sounds like some-one else put in a different connector
Possible the original plug fried. The reason for the so many stator failures in the 1200's was this plug. Wires became loose fitting and started arcing. A common fix was to remove the plug and solder the wires together. Saved having the stator go. A lot of 1100 owners used to do this as well at one time.
I am familiar with the issue, however, I was just real suprised that it was kinda done as in someone replaced it.
This is the yellow wires that are right next to the battery (left side).
Now another question is: Do I cut out what they have done, or just solder where I cut the plug out?
I inspected their plug, and it was factory style plug as it fit in the little metal holder that honda put next to the battery.
And another question, before I made the cut, I ran the bike for a few minutes. When I went to the white plug, it was very hot and the wires where actually hot. This common?
As far as testing, I have to find someone with a meter. DO I just test the voltage that comes out of the engine?
Thanks!
Rob
Has the battery been staying charged or haven't you driven it long enough to know? If you started it a few times since you got it and it worked without a boost then it is probably charging. The hot plug/wires tells you to replace the plug before you ride it again. IMO.
I rode it home (60 miles) road it around the area several times (quick trips) Started it several times in the garage and have had no issues what so ever.
I already cut the plug out, I just want to know if I should cut out the previous solder or not.
Will the wires still got hot even tho I solder it?
Rob
If the old joints are soldered good they should be O.K. My wires have never been even warm so I would say they would be cool after the repair. Unless there is another problem somewhere.
I would do it all over You will prob have to put in bridging wire as your existing wires will be too short. Use the same gauge or slightly larger and do Western union connections with shrink wrap and you'll be good to go for a long time
If you have the room I would definitely cut back to the factory wiring.Less soldered joints that way.Best to keep the joints to a minimum.
Discussion Starter #12
What is a Western union connection?
Anyone happen to know the guage of the wire?
Thanks!
Rob
Hay Rob send me a PM with you local. Iam not to far from the border my self I may be able to help you out
Rob, the short answer is to solder the three wires and be on your merry way. Honda did make a replacement plug. I believe it was called a stator connection repair kit?, or something along those lines. You may want to consider installing an EC Harness. It basically replaces all the wires to the regulator and powers the coils directly from the battery.
1 - 15 of 15 Posts
