I Posted about this bike yesterday because I'm considering buying it. He's asking 2500.00 (firm). I looked at it today, and cosmetically the bike is a 7 on a scale of 10. All the painted surfaces looked great, but the chrome around the side bags,and rear trunk had quite a bit of surface rust. My biggest concern is with the electrical system. Specifically, the stator. I took the side cover off over the battery to check all the wires and connections. He stated that the battery had been replaced within the past two weeks,and there were three wires off one side of the battery that looked new and were connected together with standard plug terminals. I didn't notice any burned wires or terminals. Every time I started it it turned over real slow (which I thought was odd), and when the engine was idling the volt meter registered about 13 volts (with no accessories on), and didn't rise when I reved the engine up to about 2000 rpm. The owner said this was because the radiator fan was running. Also, I couldn't get the controls for the auto suspension adjustment to work consistently. Meaning, I had to fiddle with them to get the meter to indicate that air pressure was changing, and I noticed no change in the bikes hight. I also did not hear a compressor running. The rear shocks looked like they might be after market. They didn't say Honda on them. One of the helmet holders on the handle bars had a home brew bracket with a 2 position toggle switch mounted to it. The owner had no idea what it was for, and we couldn't find that it controlled anything. Also, the lower running lights that are supposed to come on when the turn signal is turned on (at least according to the owners manual) didn't work at all. The turn signals worked fine. While the engine was idling, I checked the lights under the rear luggage compartment that are (if I understand things correctly) supposed to identify any problems with the computer, and they were not lit. I didn't check them as the bike was started. So, if that's how you're supposed to do it I did it wrong. The rotors on the front and back looked nice and smooth. However, the grooves on the front ones was full of greasy gunk. Is this an indicator that the shock seals are leaking? While sitting on the bike, I held the front break, and forced the front end up and down. It didn't seem to be weak. I didn't ride the bike because I wanted to ask someone with experience with these bikes their opinion of my observations. Lastly, I did notice that the bike had been either dropped, or banged into something. The clutch lever end ball was broken off, and the front fairing had dings consistent with an encounter with a stop sign, or perhaps a tree that jumped out in front of the rider. It wasn't major, but it wasn't pretty either. I mean, I understand the bike is an '86. The guy had no idea if the timing belts had ever been changed. So, from what I understand, that's a no brainer to change them before riding the bike. Thanks for taking the time to read this, I hope I've been clear, and easy to understand. Your experienced insight would be much appreciated.
Thanks, Bill
Thanks, Bill
