Anybody put non radials on their 1800 ?
:?Just asking ?
Specifically the front tire ?
I don't really know about the 1800 but I do know it's not a good idea to mix radial and bias ply tires. Handling and road grip would be different on the front and rear tires. I was thinking about putting radials on my 1500 and was also told by a tire expert that the beads are slightly different and if you put a radial tire on a non radial rim, the bead will separate from the rim in the event of a flat whereas the bias ply is designed to hold on to the rim. I don't know if that works the same for bias ply on radial rim, but it may be something to investigate.
Gregarious Greeter
Double dark siding
Putting a bias ply back tire on the front of the wing spinning in a backwards direction
I think Dave0430 has mentioned something about this and maybe is running it.
Not sure. Would have to ask Dave0430
Search "double darksiding"
Post #48 will give you the answer you seek.
:?Just asking ?
Yep, me and a whole bunch of 1800 riders. Rear tire for some small sport bike, 130/70 18, same as stock tire. Several choices, Michelin pilot activ (my favorite), Pirelli sport demon, Bridgestone battlax, and others I can't think of right now. Tried an E3 bias front tire and it was not a good choice, bad handling and worse wet road traction. A friend of mine tried some other bias front tire (don't remember what) and it was also a bad choice, made the bike very hard to turn. So I am led conclude a regular bias ply front tire is not going to work well but that may be something to do with the rear car tire.
Pwhoever
Bias/radial mixing is only an issue if they are on the same axle i. e. a car. If you have a radial rear and a bias front on a bike, it should not be an issue.
02 GL1800 w/Auto Pilot
Also, it is not the bead that is the issue, it is the mixing of radial/bias on the same axle as per 'pwhoever' said.
