I just did it, and I never did get the pod free, the air lines that hook to the compressor in the pod did not have enough slack. I ended up undoing the air hose at the junction where it splits to the 2 air shocks, and moving the now loose air hose towards the top of the frame. Then I disconnected the air supply for the front forksat the right fork cap, also had to disconnect several wires and a ground lug. That gave me enough slack to set the pod where the seat was. Then I could check the cap and coolant level . I never did figure an easy way to separate the pod from the bike, is there an easier way?
