Hi forum.Notice recently when I idle my bike(gl1500), have noticied appearent rad vapour (steam) riding up through the handle bar area. I took off both side farings and reidle the bike. The cooling system seems to be fine. It takes about 10-15minutes at idle for the temp to reach 75% hot and then both fans cut in. Fan stay on for about 1-2 minutes then cut out, temp drops and I have to wait another 10 minutes or so for the fans to cut in again. Once bike is cool, Iremoved the rad cap and no apparent fluid lost was noted, however the radiator reserve last quite low. I refilled the reserve, repeated the process and again noticed no appeared problem but a lower reserve. I am having trouble determining were the obvious rad steam is coming from. How do you get at the reserve bottle to be able to run the bike at the same time? I want to see if just the reserve lines are first damages before I continue.
