put napa hoses on rad.fit good.then seen that i did not put springs back on hoses.will it hurt to leave them off.:?:?
No lots of us run w/o springs
I hope not, cause I forgot last time too!
They are there to control the expansion of the hoses and pretty them up, but shouldn't be necessary.
If you run without the springs, the fetzer valve will fail prematurely.
(I seriously thought its purpose was as a pebble-guard)
Yes with it being only on the lower hose and called a "guard wire" I think it's place in life is to guard against sharp objects being thrown against the rubber hose.
If it is not put on and you start losing coolant you know where to look first.
Now that I have installed the fear of coolant loss into the minds of those who omitted to re-install the guard....
Have a nice day :)
Mine has the wires on both the top & bottom hoses. I left them on when I put the rad back on after it was pressure checked & cleaned. Figured they must be there for a reason.
Maybe they learned over the years they didn't need one on the top hose seeing as the hose is behind the rad out of harms way. Agree with the above, that bottom one most likely for protection.
