I have a 2008 Goldwing. The radio only plays when in neutral or when the clutch is pulled in. As soon as I let the clutch out, the radio quits. Can anyone tell me where to start looking. Thanks
1998 GL1500 Asp and 2017 GL1800 4AC
Sounds like a bad ground. Easy place to look is under the seat on the left rear, near the passenger seating area.
The next place to look would most likely be under the fuel tank.
There is a ground gang connector in front of the instrument cluster between the headlights C37. Known problem spot.
326522
Is this a triked wing? Did you recently change the battery or remove it for some reason? If so, check for a wire coming from the trike harness that connects to the battery. It should be on the negative terminal, if it’s on the positive terminal you get your symptom.
That is REALLY interesting.
