Hi wdwild 1, :leprechaun:Welcome to the nest. :clapper:The others are correct, this is a fault with your radio. I hope your :18red:is still under warrenty. Have the dealer look at this for you, he will sort out the problem. :jumper:my radio only plays A.M. station...it will not change toFM, WBor AUX.
for some reason the two top rows of button are the
only once that works... the two bottom do not work.
That's good to know Phil. As the whole thing needs stripping out for removal it makes sense to check out the buttons.i had this problem on my radio but it was along the top row of buttons they would not turn the cb off, switch from speakers to headsets so i took it out and stripped it down and it transpired that the rubber buttons had moved under the membrane and got stuck. Cleaned everything up and reassemblied everything and it worked fine. Might be worth trying before sending it for repair.
rgds
Phil
