I've been thru Rockhill SC.......
OK the biggest bikes they make them for is the Sportster and VTX 1300 and the longest tube is 4"..... That should still keep the joint in between the triple tree offering a bit more strentgh. FeButter was talking 6" on a Brit bike....the trees were alot shorter cause the bikes were alot lighter and smaller.
Must be some math there that makes them safe though. Take putting in a set of progressive springs, look at the end tube and fine thread the cap has to hold it. Technically you could say one good chuckhole and high impact would blow that cap(s) off.....and the front end would collapse. Those thread can't be holding much, it's so easy to cross thread the cap when pushing all that pressure down. And what's it got 4 or 5 threads to the bottom.
We used to buy longer tubes for Harleys back in the day, I wonder if the still make those? You had to tear the front end apart, but the tubes were one piece. How about some 8" over GW tubes.... They used to make them so long you couldn't see over the risers.....ah it was always saftey first back in the 70's......I think 'Amen' made them, I bought a couple rigid frames off them too.
