1 - 2 of 2 Posts
I'm going to have to replace my right rear shock on my 1500. Should I replace it with a used take-off shock or new 416 Progressive shocks?
The take-off shock doesn't have oil in it. How big a job is it to refill it?
Need your help, guys. Thanks
:praying:
silverider wrote:
I'm going to have to replace my right rear shock on my 1500. Should I replace it with a used take-off shock or new 416 Progressive shocks?...
> If you're willing to upgrade, then the 416's are much better than stock.
> Why do you have to replace it?... Perhaps you could rebuild it instead? (eg The Seal and Boot only cost about $25, and takes an hour to replace)
silverider wrote:
...The take-off shock doesn't have oil in it. How big a job is it to refill it?...
> Very easy... Simply measure the correct amount into a cup, then draw it into the shock using a rubber hose while pulling the shock to extend it's length.
1 - 2 of 2 Posts
