I am in the process of changing out the rear rotor and brake pads. I have the caliper removed and the pin retainer removed. The next step in the manual is to remove the pad pins. According to the drawing, the pins are removed from the piston side of the caliper. Is this correct? They appear to be frozen in place. I just want to make sure before I go get the ballpeen hammer and drift punch. I have soaked them with rust penatrent for about a day or better, Still won't move with mild mannered persuation. Pistons don't want to move either...any slick tricks to move them back?
Just went out to remove the caliper from the bike and take it to the bench and found I can't move the bolt that holds the brake hose onto the caliper. Probably going to need the breaker bar I had to use to remove the drain plug on the oil pan.
Bob
_________________
1984 Aspencade
Bob
_________________
1984 Aspencade
