1 - 3 of 3 Posts
When I tore this stuck rear brake apart It had a third brake plate without the lining, being used as some kind of shim I guess so the piston won't have to come out as far. I removed that and rebuilt both caliper and master cyl. with all new parts. I cannot get the pedal to not want to bottom out on the frame when you hit it hard. The bike will stop but I don't like the pedal travel. I have powerbled , forward and backward bled. There is no air in the system. I have adjusted out the rod as far as it will go on the piston. Still it feels mushy and alot of travel Help Jim
Jim you have too many rear brake problems!:waving:
1 - 3 of 3 Posts
