1 - 14 of 14 Posts
Impersonating a mechanic
Attached is a picture of the rear brake master cylinder with the circlip installed. What is the purpose of this circlip? It's not holding anything in place on my bike. Does it just keep the washer that's located just below the peen on top of the linkage from contacting the casting? Or what? Thanks.
give us a pic and we will give you a fruit cake and maby some help
2007 1800 Crucible Orange
in the photo it appears to be holding the washer , piston , and spring in place . Once attached to the frame and linked to the brake pedal I guess its only holding the washer , as the pushrod is holding everything else .
It holds everything together. If you leave it out or if it comes out on it's own the pedal will rise way up and pull all the guts out of the MC.
dave o430 is right
Discussion Starter · #9 ·
Maybe I have it installed wrong, but this one's not holding anything now. It's just sitting in the groove at the bottom of the master cylinder. Is the washer on the pushrod supposed to go underneath the circlip, as you look at it in the photograph?
Discussion Starter · #10 ·
Dave,
If my post #9 is correct, what you're saying makes sense to me. It wasn't set up that way when I took it apart though. And there was "peanut butter" and dried up white stuff -- must have been drier brake fluid -- all over the inside of the boot. Lordy.
Boy, I'm glad you guys are out there. It takes a lot of time (and brains) to become a good mechanic, doesn't it.
I believe there should be a spring. rubber cup, aluminum piston then the washer on the push rod then the circlip to hold it all together. Make sure very clean before assembly and clean the pressure relief hole, then bleed system.
Junior Grue
Yes the push rod seems to be missing in the picture posted.
Discussion Starter · #14 ·
You're right. That's the way I had (mistakenly) put it together. The washer, of course, is not underneath it. I should have been able to figure it out, but I mis-read the diagram in the manual. Thank you, and everyone else, for your help.
1 - 14 of 14 Posts
