If it's the Hondaline one, its very easy. Open the trunk and remove all the phillips screws holding the inner liner and trunk latches to the inside of the lid. You won't need the Honda template to drill the mounting holes as there are four faing "X" marks there already on the inside of the trunk. Drill a small hole in each first to get them centred, then drill a 10mm hole in each. Drill another 10mm hole for the wire to pass through. I sure hope the special mounting bolts were in your kit!
