1 - 3 of 3 Posts
can rear brakes freeze do to cold weather.the reason i ask i rode it a couple weeks ago.and pedal went down farther than normal.felt like it had air in the line.now today in a heated garage pedal feels good.should i clean master cyl.and blead brakes or just leave alone:?:?:?
If the brakes feel normal now I wouldn't bleed them but I would check the level of fluid in the reservoir just to be sure all is well. It could have been something that caused one or two of the pistons to get pushed back into the caliper, perhaps a stone or some such. If that happens it takes more than the usual amount of fluid to apply the brake which will require a longer pedal stroke.
1 - 3 of 3 Posts
