1 - 9 of 9 Posts
Greetings and Ho, ho, ho, I rebuilt the rear master cylinder and could not get it to prime. I removed it for a bench test. The only time that I can get it to suck fluid into the unit is to hold my finger over the discharge to create back pressure.
When the system has been opened, how does one creat enough back pressure to prime it? Thanks, Lew
Greetings, While the master cylinder is held in a vice and no hose connected to the discharge, I hold my finger directly on the master cylinder discharge. It creates enough pressure to squirt fluid around around my finger. When my finger is not over the discharge, it will not suck fluid in. The cylinder intake is flooded. Hope that helps. Thanks again, Lew
Hi if the system has been drained to expel air from the system the procedure for bleeding the brake is best carried out by two people make sure fluid level is at max mark the reservoir must be kept at least half full of fluid during the bleeding procedure. attach a clear plastic pipe from the bleed screw to a container with some clean fluid in it. Press the lever to build up pressure then release bleed screw half a turn close the bleed screw before you get to the end of the travel then release lever and repeat until presure and no air is in the system. hope this helps.
First and foremost on these cylinders, did you confirm that the small hole in the cylinder body (return fluid feed) was clear? It will be very difficult to bleed if this is plugged (and will lock up the rear wheel when you ride it and brake a couple of times - been there, done that).
If clear, I always use aMityVac to bleed the rear -it seems to work the best.
Ernie, 81 GL1100.
Thanks for your help!! What is the best way to clear that hole. Will a small wire go through the hole? Thanks again, Lew
Someone on this board suggested electric guitar strings/wire. I bought 3-4 different sizes at about .99 cents each and they work great.
I just clamp a wire from a wire wheel in a small vise grip and poke out the hole. You don't say which 1100 you have, if it's an 83 you need to bleed the linked front brake first, always bleed the one farthest away from the master cylinder first. If you have an 80-82 model the brakes aren't linked this doesn't apply.
One other possible bleeding problem that crops up now and then is a plugged bleed screw on the caliper. Usually these can be cleaned out with a bit of hand reaming with a properly sized drill bit. If you have one use a vacuum source to pull fluid into the system from the caliper bleed screw as aternie mentioned.
Not to insult you, but you did install the rubber piston cup with the open end facing the output end of the cylinder and with the large end of the spring facing the output end? If either of these are backwards the master won't work. (Don't ask)
1 - 9 of 9 Posts
