Hey all...
I suspect I have a clogged relief port in my rear master cylinder (brake pads don't retract far enough when rear brake pedal is released which causes them to drag). I checked all the linkages to see if they were free and they are so nothing is hanging up there.
I had this happen once on my front brakes and that microscopic relief port hole was visible looking down through the reservoir. I unclooged it by pushing a guitar high "E" string into it and it is fine now.
Is that hole right under where the brake fluid line enters the rear master cylinder coming from the rear brake reservoir...if not, does someone know exactly where it is?
Thanks!
Hey all...
Thanks!
