rear shock 82 aspencade
401 Views 1 Reply 2 Participants Last post by  Raveller
after takeing rear tire off.i noticed on bottom of right shock all i have is a rubber bushing.is there a metal sleve that goes in there.like on the left side.i looked to make sure that it was not on stud nothing.or dose it just slide on stud with just rubber bushing.it seems tight when i took it off to get tire off????:?:?
1 - 2 of 2 Posts
Hi,
Yes there is one on the one side only. Check any parts diagram and you will see there is only one sleeve called for. I think it is because there are different size bolts.
Good luck,
Greg
1 - 2 of 2 Posts
