The rear shock on my GL1500 1991 is losing pressure. I've checked and replaced the shock itself. As far as I can see, I have an air leak from the top of the solenoid valve on the air distributor unit where the wire comes through. Has anyone had this problem before?. Will I have to replace the whole air distributor assembly, or can you get the solenoid on its own?
