I have my 82 1100S I've been rebuilding. I was wondering about the oil in the rear shocks. Should I replace it? I did blow out all the air lines and reconnect everything. Aired them up to 56 PSI and when I checked them a day and a half later, they still had 56 in them. And if I do change the oil in them, can I just pour it out the air hole and then refill it from there also? And, if I don't need to change it, is there a way to check to see if there is enough oil in them? Thanks, Ray....
