82 aspencade.i have a set up where i can put air lines on back shocks.and air them up manualy what i need to know ishow do i plug air pump so i can still air up front shocks.:?:?:?
krazy al can you reword your question, it isn't very clear. Some of the Aspencades had compressors and controls that would charge the front and rear suspension. Check out some parts diagrams.
On my GL1200, my front air pressure is max 6psi, I dont want him blowing the seals
GOD Bless,
jerry
what i have is air comp.but they leak down i think through the pump.what i have is air line off a interstate i think.for back shocks air manualy.what i want to know is how do i plug air comp off.so i can still air front shocks thru air pump.as they still hold air.back shocks are not leaking as i put manual air lines on temp.and they will hold air.
Just change the forks from an 80-81 if they will fit, and also to remember to get the crossover line. My only concern if this works, will the superbrace on the 1200 fit on the 1100 shocks? They are very expensive since the 80-81 (Roughly $175.00) did not come with a superbrace. Hope this helps.
Nightrider1
