1 - 11 of 11 Posts
Guys,
Installing the rear speaker harness on my '98 Aspencade. The instructions state to unplug a white four-pin connector on the main wiring harness on the left side of the bike. I'm having difficulty finding this connector. Has anyone done this mod that can direct me where to disconnect?
Thanks in advance.
It is stuffed down in a big rubber cover, several connectors in there, just forward of the shock mount.
Stu,
Are you referring to the connector that goes up to the two rear speakers? I'm looking for the connectors that go to the fader control harness.
Ah yes!
That would be under the left side shelter, forward of the reverse lever.
Thanks Stu! I found the connectors....they were up to the left of the airbox. Alot higher up than I expected.
Loulou-67
Hello from france
have you some pictures of it
they were up to the left of the airbox. ????? in a box black near the airbox ? I see something on this picture the green ? but with the fader audio honda you have three connections ? Thank you for your answer. I want to put the fader yesterday bayt i haven't do it - i don't find the connections - sorry for my english - best regards
Hello Loulou-67
The connector number is c300, white 4 wires, blue/green, gray/black, red/green, brown/black. Yes that is the area.
Hello Loulou-67
ok thanks but in the shema in my picture upside - what
colour is it ? The red section ?
best regards
__________________
__________________
check the 4 wire connectors and the wire colors. I don't have an Aspencade to verify, just the repair manual and it says the color of the connector is white.
Lost on this *****
And this is where the connection is for the rear speakers,,,,,,,,,
1 - 11 of 11 Posts
