1 - 20 of 21 Posts
how much should the rear tire spin while off the ground? Just trying to find out if i have unusual brake drag or not. i have all my bags off and can spin it pretty good and doesn't make a full rotation.
What say you?
yes, it is in neutral :cool:
Take a hammer and a hunk of 2x 2 wood and whack the caliper a couple of times. If it starts spinning better then you know you need to investigate.
Guru
Yup, brake drag is a comman problem. Check for tire rub to rule that out as well. Your turning a few gears & a shaft so you will have a little resistance but not much. you should be able to roll that tire with 1 finger!
When i have my 08 on the center stand, I spin the rear tire and it starts dragging after about a half rotation. Is there an adjustment to keep it from doing that?
Guru
No adjustment. You must ensure that your brakes dont drag, Your rotor is not warped & your tire does not contact the frame during its full revolution.
Check the gear oil level in your rear hub, I change mine every fall.
If you pull your rear tire, you must grease the splines in the rear hub with molly 60 grease, nothing else!
No splines on an 1800 hatchetman.
Guru
Does an 1800 not have a final drive like the older bikes???:baffled:
Yes it does but it has a single side swing arm and the wheel bolts to it like a car instead of slipping onto a spline and having an axle through it.
Discussion Starter · #9 ·
the tire will not roll with one finger. as is said i spin it as hard as i can and it does not make one rotation.
Well i have everything off the back now, fender, lights, bags, etc. so it would be a time to do this.
assuming fresh gear oil...if the brake is dragging then caliper rebuild or warped rotor would be it?
Banned
everytime I remove/replace a wheel I have to make sure it does move freely , sometimes I have to "spread the forks a little ,sometimes I have to give them a whack on one side or the other , I would take it loose and re-tighten everything on the rear , you will figure it out.
Guru
if your brakes are dragging you should be able to hear them rubbing & I think you might be able to see the pads now with some stuff out of the way.
If your caliper isnt hooped, it might just need cleaning where the pads slide on the caliper housing. The pads will not retract far away from the rotor, but the pressure from a brake application should drop to zero when the brake is released.
Discussion Starter · #12 ·
well got home and tried pulling my brake off and guess what? i guess i got a little drag because i can't get the brake off...it is so tight on the rotor.
what you think? any way it will relax at all withoutit being rebuilt? looks like the pads need replacing too.
thanks.
Banned
Is you brake pedal moving freely? No rust?These will get real hard to move , use some penetrating oil and work it up and down till it frees up.
Discussion Starter · #14 ·
brake pedal is moving fine. brake works just is draggin. I got the brake off. I guess i will clean the pistons real good and push them in put new pad on and see if that frees it up.
do you think this will help or will it still bind? that is the question.
My '08 does exactly the same thing. I have also noticed that I can't spin it more than one revolution before a ride. However after a ride I can spin it a couple of revolutions. I guess there is less drag after everything warms and loosens up. However I can hear the pads dragging in either case. I used to obsess about it but the roter is never hot so I don't worry much about it.
Guru
clean the piston. there might be a ring of corrosion behind it not letting it retract. that should fix your problem! you can blow it out gently with compressed air.
Thanks for the advice. I may try that. There may be something else there but I hope it isn't corrosion as the bike is only 2 months off the showroom floor.
Guru
Hey Red Ron, Is your wing under warranty?? If it is, Have your dealer deal with your drag issue, It should be their bill if you just bought it!
I didn't think about trying it after i ride for awhile. My abs break lite stays on until i roll about 6 feet infirst gear. I wonder if that is the problem. I am taking in for service next week and tell them about it and see what they find out. It appears maybe that the brake doesn't release all the way until you take off.
Discussion Starter · #20 ·
well, it seemed to work. cleaned the piston, new pads and the tire is spinning much better than it was. now lets see if it helps the gas mileage.
1 - 20 of 21 Posts
