:action::clapper:Woo-Hoo I just replaced the rear tyre on my 83 Aspencade 1100. I was dreading it cos of all that luggage. Well I stripped all the racks off and intend to leave them off for the winter. The tyre change was really easy with no probs at all tho I would hate to do it in an emergency at the side of the road. Im leaving the luggage off too because i intend to trike my ride at some point in the winter too. But am looking for a spare swingarm so that i can build the trike mod then replace the whole thing in a day without too much down time as I use my bike every day. Well all I can say is dont let the thought of maintenence put you off cos its not too scary once you get started.:action::action:
Yea, the rear tire replacement on the 1100's isn't bad at all. I just get the rear end off the ground high enough and only have to remove the left saddlebag.
How do you clear the exhaust without taking the bottom shock bolts out?
Well I just took the nut off the shaft loosened the shaft pinch bolt then tapped the shaft out , there was no clearance issues at all.
