Rear well noise
301 Views 4 Replies 3 Participants Last post by  steve worth
I have a 1987 Gl1200 interstate and when moving in all gears i get a slight rubbing sound (WHOOOSHING sound) from the rear of the bike. This only happens when in gear at any speed when you pull in the clutch it stopes so i would not think it was the brakes but thats kinda what it sounds like. I have checked and replaced the rear diff. lube with no change in sound. The old lube looked clean and free from any grit. Im at a lose please help. Thanks.:?
did ya just get this wing or have ya had it for awhile , i have a 85 aspencade and never owned a wing befor , always had crusers with loud pipes , i hear so many sounds now with the wing it scares me , befor with loud pipes ya heard nothing , just saying , this is my problem , yours may be something to worry about ,
I have had it for two years and it just started about a month ago.
ok , u would no then , i'm still trying to find out if my noises are normal or a problem
Check the swing arm isn't rusty. They can swell on the joints and foul the wheel. It did it on my 1500 and maybe 1200's could do the same?....Steve
